Hi,
I have a system with a GTX980 that was working for years. I lost output on my GTX980 last week. Symptoms were (no pops or bangs) and after booting past the BIOS and Windows OS loader I would lose my screen output just before the Windows 10 login screen loaded. I and have been trying to figure out if the graphics card or the mobo is the problem. As I was troubleshooting I restored to a system restore point 3 days before the problem happened and uninstalled NVIDIA drivers (thinking it was the problem) and now the graphics card does not show up in Device Manager. During all this the led and Fans on my Graphics card turn on.
Windows 10
I5-4590
ASROCK B85M-ITX
Corsair GS600 PSU
16GB of Kingston RAM
MSI GTX 980.
I can boot up and use my system because the integrated graphics card works. No software updates were installed that would explain the lost of my GPU. I upgraded my BIOS after I lost the GPU and that didn't fix anything.
My graphics card does not show up in Device Manager under Display adapters or anywhere. After I lost my graphics card I uninstalled the NVIDIA GEFORCE drivers thinking it was a driver update. I can't install new GEFORCE drivers because it can't find any GPU on the system. I also put an old SSD that had a (1 year old ) clone of my OS and was working with the Graphics card into my system to boot and that also didn't recognize my graphics card.
I put a PCIe 1x Ethernet adapter card in by PCIe 16x slot (the graphics card slot) and Windows recognized the ethernet adapter card.
Is that enough to tell that the graphics card is the problem? Is a PCIe 1x card enough to tell that my PCIe x16 port is functional?
The one last thing I can try to do is disassemble 2 systems and cobble together an Ivy bridge I7 and the PSU from my current system (with a H61MV-ITX) MOBO to see if the graphics card will work on that system.
Thoughts?
Thank you!
Windows 10
I5-4590
ASROCK B85M-ITX
Corsair GS600 PSU
MSI GTX 980.
Thoughts?
Thank you!
