Question Help with temperature monitoring software ?
which readin is my actual cpu temp.....................I thought it was package but Im not sure now
The Temperatures -> Package value is the overall temperature of your CPU - including its cores and heat spreader. If you want to see the values for the individual cores then hopefully they'll be displayed by expanding the "Cores" section.
Some folks consider HWiNFO to be a superior tool. Make sure you click on the "Sensors only" option when you start it otherwise you'll be bombarded with lots of information.
The package is often a measurement from outside of CPU, whereas the individual cores are from up to 600 odd sensors on the Ryzen CPU.
I generally just track core temps as it doesn't bounce around as much as Package. I wonder what best would be to track on a dual ccd CPU such as his.
Curious what it looks like
it might just have a core temps value for both ccd. or a combined total.
okay and one more question I have 2 sensors on the fan speeds for my cpu one says cpu thats over 4000 rpm and the other is fanin4 which is 900 rpm do I have my aio fans and pump pins swapped around
