Help with this system build for video editing
dmantnt
16
hi all i am an editor but on a super tight budget i would like my system to cost 1000us or less i have a system in mind but need advice i am torn between going lga 2011 or lga 1155 i have been editing mostly achvid 1920 x 1080 24p
here is what i put together it came over my budget but would like some honest advice thanks
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case Item #: N82E16811129066
3 Western Digital WD Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -BareDrive Item #: N82E16822136533
one system drive the other 2 for storage etc
PNY VCGGTX660XPB GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card Item #: N82E16814133470
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power ... Item #: N82E16817139021
G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9Q-16GBZL Item #: N82E16820231497
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131801
Intel Core i7-3820 Sandy Bridge-E 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W Quad-Core Desktop Processor BX80619i73820
Item #: N82E16819115229
Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler
Item #: N82E16835608024
LITE-ON Black 12X Blu-ray Burner with Blu Ray 3D Feature SATA IHBS112-04 - OEM
Item #: N82E16827106369
this system comes to $1587.00 us
any suggestions would be welcomed thank you i also would not mind alternatives to my build thanks
djangoringo
In my opinion, if you want to cut costs, the lga 1155 is the platform to go, the i7-3770k is superior to the i7-3820, for lga 2011 only the i7-3930k is worth, but it costs more than 500$.
You can see the performance difference between the two cpus : http://www.anandtech.com/bench/Product/551?vs=523
I recommend going with a 256GB ssd, and just a single 3TB for storage.
A 550w psu will do for the system, a 660 gtx is a good option, but i rather get an asus one, my suggestion :
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($329.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Newegg)
Motherboard: Asus P8Z77-V LK ATX LGA1155 Motherboard ($124.99 @ Newegg)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory ($84.99 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($139.99 @ Newegg)
Storage: Samsung 830 Series 256GB 2.5" Solid State Disk ($199.99 @ Newegg)
Video Card: Asus GeForce GTX 660 2GB Video Card ($199.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($45.98 @ Newegg)
Power Supply: Rosewill Hive 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($49.99 @ Newegg)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer ($74.98 @ Newegg)
Total: $1285.88
g-unit1111
I agree - the 3820 isn't really worth purchasing.
Here's a build I would suggest:
CPU Cooler: Noctua NH-U9B SE2 37.9 CFM CPU Cooler ($60.99 @ Newegg)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($124.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($84.99 @ Newegg)
Storage: OCZ Vector Series 128GB 2.5" Solid State Disk ($139.99 @ Newegg)
Video Card: EVGA GeForce GTX 660 Ti 2GB Video Card ($304.98 @ Newegg)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case ($80.00 @ Newegg)
Power Supply: SeaSonic S12II 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($85.98 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($16.99 @ Newegg)
Total: $1313.89
(Generated by PCPartPicker 2013-01-24 18:01 EST-0500)
dmantnt
16
hi thanks for the support i have been messing with some other builds trying to carry down cost but not loose performance
option 1
fx 8350
asus sabertooth 990fx
antec 300 illusion case
16gb g skill ripjaws x 1866 ram 2x8
cosair tx750 v2 power supply
asus gtx 660 video card
lg wh14ns40 blue ray burner
seagate sata 3 7200 rpm 1tb hard drive system drive
seagate sata 3 7200 rpm 1tb hard drive storage drive
total $1093 appox at new egg
option 2
i7 2700k
asus p8z68 v gen3
total $1193 appox at new egg
option 3
i7 3770k
asus sabertooth z77
total $1283 appox at new egg
option 4
i7 3820
asus sabertooth x79
32gb g skill ripjaws z 1866 ram 4x8
total $1463 appox at new egg
above system with i7 3930k $1732
i kept to items i know please feel free to reccomend differently stil trying to keep the system as close to 1000us
your comments and input are greatly appreciated
g-unit1111
Honestly - none of the above. The FX-8350 is a decent CPU but for multimedia authoring I'd rather go Intel. The 2700K is outdated, the 3820 isn't really better than the 3770K. The third build has probably your best bet for CPU but that choice of motherboard isn't really the best - it's overrated and very expensive for what you get. You could cut down on the motherboard and put more into the case and GPU.
Maybe try this:
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($229.99 @ Microcenter)
CPU Cooler: Noctua NH-U9B SE2 37.9 CFM CPU Cooler ($59.99 @ NCIX US)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($44.98 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Amazon)
Video Card: EVGA GeForce GTX 670 2GB Video Card ($368.98 @ Newegg)
Power Supply: PC Power & Cooling Silencer Mk II 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($104.98 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($15.98 @ Outlet PC)
Total: $1239.87
(Generated by PCPartPicker 2013-01-24 21:06 EST-0500)
dmantnt
16
thanks for the help
some things i require are
a blue ray burner for backing up video for clients
firewire
some questions are asrock boards any good ?
i stuck to brands i know but what else could be changed to keep cost down but quality high and i could always add on stuff as i get cash or needed
dmantnt
16
oh i kept building the lga 2011 since i was wondering if new chips might be made for it in the future that i can upgrade to
also i am not good with what memory works well with what board and processor if i have dumb suggestions let me know
g-unit1111
Yeah they're not going to be much of an improvement over what's out now, there's no such thing as future proofing even on workstations. i
dmantnt
16
i would like to order this system by this weekend since i have sold all my other stuff and am working with a netbook right now that is driving me crazy
dmantnt
16
ok how does this look tweak where u have to to reduce cost or increase performance
Intel Core i7-3770 Ivy Bridge 3.4GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770
Item #: N82E16819116502
ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813157293
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GAB
CORSAIR TX Series CMPSU-750TX 750W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Compatible with ...
Item #: N82E16817139006
ASUS GTX660-DC2O-2GD5 GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814121660
LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL Blu-ray Burner, Bare Drive, 3D Play Back (WH14NS40) ... - OEM
Item #: N82E16827136250
Crucial M4 CT256M4SSD2 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
Item #: N82E16820148443
total $1167
djangoringo
That's a good ssd for the price, you can have cheaper cases, the corsair 200R in newegg is a good option, in my opinion.
The rosewill hive modular with 550w will help to cut the costs, it's at a low price in newegg.
You can see here for reviews of the series : http://www.anandtech.com/show/5674/rosewill-hive-550w/6
http://www.hardwaresecrets.com/article/Rosewill-HIVE-650-W-Power-Supply-Review/1460/11
http://www.guru3d.com/articles_pages/rosewill_hive_750_watt_psu_review,7.html
There's also the OCZ ModXStream Pro 600W there it's cheaper, see the review : http://www.hardwaresecrets.com/article/OCZ-ModXStream-Pro-600-W-Power-Supply-Review/936/9
Also make sure it's the i7-3770k if you want to overclock the cpu, otherwise the i7-3770 is a good choice + h77 motherboard, like for e.g. : the h77M or the h77 pro 4 mvp fro asrock, they're cheap and offers plenty of features.
dmantnt
16
based on my not getting many responses i think i went crazy and changed the build again i am very grateful for your assistance since i have no one to throw ideas at
look at this build and what i ask if it is not a problem based on my needs i would like u to do a custom build for me that i can look at
last build
i7 3770k $330
gigabyte ga z77x d3h $134
( i switched from the asrock since no one could tell me if it is a quality board i decided to stick to asus or gigabyte i chose this board based on sata 6gbs and usb 3.0 connections)
g skill 16 gb ares ddr3 1600 $80
(depending on savings i could maybe add another 16gb)
Evga superclocked gf gtx 660 02g p4 2662 kr $230
(looked good)
cosair builder series cx600 $70
(used newegg powersupply finder)
lg blue ray burner $70
(cheapest model on newegg i need to back up the videos i shoot and stock footage ) i wanted to install 2 in fact
crucial 256 ssd $165
( everytime you guys showed me a system it had a ssd so i decided to byte the bullet - i have a usb 2.0 external 2tb i could use that for storage)
antec 300 illusion case$65
( i personally find choosing a case hard so i realised this one well liked and stuck with it )
i hope i didnt forget any thing is appox $1050
thanks again
i am looking forward to your response
also i have to order send to my cousin to assemble and ship to me in the caribbean so i am being extra carefull
i dont want it shipped in parts here and i have to ship backstuff
djangoringo
The asrock extreme 4 motherboard is fine, either the gigabyte, asrock or asus has all the features and quality.
16GB of ram is fine for such needs.
Don't forget to add a cooler if you want to overclock the cpu, like the hyper 212 evo, which is efficient and cheap.
That's all.
PCPartPicker part list: http://pcpartpicker.com/p/zw2o
Price breakdown by merchant: http://pcpartpicker.com/p/zw2o/by_merchant/
Benchmarks: http://pcpartpicker.com/p/zw2o/benchmarks/
CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor ($233.98 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler ($19.98 @ NCIX US)
Motherboard: Gigabyte GA-B75M-D3H Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
Memory: Patriot Viper 3 16GB (2 x 8GB) DDR3-1600 Memory ($84.99 @ Newegg)
Storage: Mushkin Chronos 120GB 2.5" Solid State Disk ($99.98 @ Outlet PC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Amazon)
Video Card: EVGA GeForce GTX 670 2GB Video Card ($359.99 @ Newegg)
Case: Cooler Master Silencio 550 (Black) ATX Mid Tower Case ($90.93 @ NCIX US)
Power Supply: SeaSonic G 550W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply ($85.99 @ Amazon)
Total: $1137.80
(Generated by PCPartPicker 2013-01-25 12:29 EST-0500)
Base Total: $1166.81
Combo Discounts: -$14.00
Mail-in Rebates: -$20.00
Shipping: $4.99
Total: $1137.80
built on power, silence and speed :D
dmantnt
16
thank you for all your suggestions - iceclock just gave me a new idea but i am not sure about that route though it looks great
here is what i have come up with as indicated please give your suggetions
case
Corsair Carbide Series 200R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
Item #: N82E16811139018
reason - i like it has usb 3.0 headers - thanks djangoringo
EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814130826
reason - based on cuda cores and budget - but still want advice
Rosewill HIVE Series HIVE-550 550W Continuous @40°C, 80 PLUS BRONZE Certified, Modular Design, Single +12V Rail, ATX12V v2.31/EPS12V ...
Item #: N82E16817182131
reason - i am going with it based mostly on djangoringo's info posted about it
G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C10D-16GAO
Item #: N82E16820231558
reason - not sure - is this good enough ?
ASRock Z77 Extreme6 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813157295
reason - i have never used asrock and am hesitant but board has everything i need - esata 6 gbs and firewire i could go with a lower cost board like the extreme 4 or the gigabyte z77x d3h or even a lower asrock but i would have to add a firewire card
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
Item #: N82E16819116501
this i am 100% sure about
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel ...
Item #: N82E16835103099
reason price and reviews
reason price
Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148840 Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
reason price sata3 7200rpm and i need some storage
SanDisk SDSSDP-128G-G25 2.5" 128GB SATA III Internal Solid State Drive (SSD)
Item #: N82E16820171646
reason - most of u advised i get a ssd for boot and i have sandisk 32gb compact flash cards working well and price
my total shipped from newegg $1200
any suggestions
dmantnt
16
hey fellas sorry about the dissapearing act but i have been away - can u guys reccomend the same sytem i laptop form
one of my clients wants us to work on site so i am looking for a laptop
dmantnt
16
hi how u doin?
thank for all your assistance with the build i posted a new question and would like your advice
the client was planning to use the build to edit for would like me to be portable - laptop
i have been checking around i am looking at lenovo w530 / w520 are there any other brands or places i could check
i am trying for the same performance as possible
