Greetings to all:
I've a loop with 4 blocks ( Maimboard , CPU, GPU and a block of aquaero XT ) ; one reservoir Aquacomputer Aqualis ; one triple and one quadruple radiator ; the loop is moved by 2 pumps MCP-35X with dual top EK , also has 2 Aquacomputer high flow sensors . All pumps at100% gave a yield of 215 l \ h ( approx ) in the loop .
The point is that my reservoir and dual top of the pumps were joined by two elbows of 30 degrees , among which there was a section of tube (the group forms 90 degrees in a relatively short space) very short (5 to 6 cm long) that , over time , to do some flexion , observe who was folding , with the consequent danger of flow restriction.
I replaced that section of the loop by a combination of fixed parts (some Nozzle adapters coupling ; a single fiiting 90 degree swiveling ; etc) forming a rigid assembly with 90 degree bend fairly smooth (the single 90 degree fitting is based on three 30 rotating bodies each) without the danger of tube section was folding by forcing the curve being so short in length.
My problem is that I found the unpleasant surprise, since I can't find explanation , that now only gives me 128 l \ h ...............This is why I ask for help from anyone who can give me an explanation that could happen . I can't find a logical explanation , since I've only replaced nothing more that a potentially dangerous short section for something better and less restrictive.
Of course , I checked the operation , separately , of both pumps, for if he had broken some by chance; is more , I haven't even been forced to completely empty the liquid loop (I've a valve drain on the lowest part thereof) ............... i don't know , i can't find explanation for this and I am blocked without knowing what to do.
Thanks in advance
Thanks in advance
