Question Help with upgrade
May 23, 2019
17
Hello everyone, I'm here looking for advice on what components to upgrade next. I built my pc from scratch less than 2 years ago I believe, I didn't know much, asked some friends for advice and tried to make a budget build. Screwed up here and there but eventually got my pc together, could play pretty much anything on high settings with AA AF and v-sync off but now I feel I can try to invest and get it better. Was mainly considering getting a better case with more fans and a decent 500gb ssd but I believe that my motherboard is holding me back because it has no overclock capability.I mainly play pubg and apex, what would be the most efficient upgrade for me?
Here are my specs:
B250M Pro-vd (ms-7a74)
PSU:evga 450b 80+ bronze 450w
Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
Msi Radeon RX 580 Series 8 gb
DDr4 kingston 2133MHz 8gb dual channel ram
SSD kingston Suv400s37120g 128gb
Western Digital blue 5400 rpm
Thanks so much in advance for your input. have a great day
liamwhalley20
Proper
Nov 27, 2018
157
24
110
I'd upgrade the psu, motherboard and ram personally, 16gb of ram will give you more breathing space for gaming plus with a z motherboard you can then overclock and squeeze more performance out of that cpu
May 23, 2019
17
I've seen People argue that it wouldn't be worth investing on a 7th gen mobo, but what do you honestly think? Cause upgrading the Motherboard would be my top choice atm
WildCard999
Herald
May.
PCPartPicker Part List
Storage: Intel - 660p Series 1 TB M.2-2280 Solid State Drive ($109.00 @ B&H)
Power Supply: SeaSonic - FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($73.14 @ B&H)
Total: $182.14
Generated by PCPartPicker 2019-05-23 08:59 EDT-0400
June.
Memory for current motherboard & platform upgrade (Ryzen performs much better with fast memory). Sell your current memory.
Memory: Team - T-Force Vulcan 16 GB (2 x 8 GB) DDR4-3200 Memory ($74.99 @ Newegg Business)
Total: $74.99
Generated by PCPartPicker 2019-05-23 09:00 EDT-0400
July.
Ryzen 3rd Gen CPU.
X570 or B450 Motherboard (with updated BIOS)
August or later.
GPU upgrade, to make it worthwhile I'd go RTX 2060/2070 or better also including AMD Equivilent (RX 30XX series?). After the GPU upgrade I'd consider a monitor upgrade if your currently at 1080P.
Reactions: DMAN999
hftvhftv
Herald
May 26, 2014
572
53
11,090
21
May.
Total: $182.14
June.
Total: $74.99
July.
Ryzen 3rd Gen CPU.
August or later.
I'd agree with this upgrade path, there isn't much you can do with the 7th gen series of Intel CPUs, as the motherboards aren't compatible with 8/9th generation CPUs. The 3rd gen Ryzen CPUs are going to support PCI-Express 4.0, and will have increased core counts, with a 7nm die shrink, which will at the very least force Intel to once again either drop their own prices or increase core counts drastically.
May 23, 2019
17
May.
Total: $182.14
June.
Total: $74.99
July.
Ryzen 3rd Gen CPU.
August or later.
You're the man, thank you so much for the help
WildCard999
Herald
Yes all of those are compatible with your current motherboard. For the memory when you enable XMP in the BIOS it will run at 2400mhz instead of 3200mhz as that's the max speed the motherboard supports but it's not a issue as memory speeds make little difference in gaming for Intel.
