Help with upgrading graphics card
Andres_8
109
Hello, my actual specs are:
Graphic card: Amd HD 7750
CPU: AMD FX 6100 six-core processor 3.3 ghz
RAM: 6 GB
Games from the previous generations run at smooth 50-60 fps at high-(sometimes ultra)
but now i'm onto new generations games, and I hate running games like black ops 3 at 45-50 fps at medium settings, and with stuttering issues, also running fallout 4 really crappy, so, I will add 4 more GB of ram to make it 10 GB of ram, my cpu is fine I've been told, so I've looked at some graphic cards, I've seen the nitro r7 370 4 gb ddr5, the price is fine for me ( around 220 dollars ) and i think it'll do its job, i want smooth 60 fps at high-ultra settings if its possible, so, can you recommend other graphics card for me that'll get games like BO3 and fallout 4 at 60 fps on high settings? thanks.
I have been looking at the same thing...getting a new gpu around that price range (200)
After hours of research, i found two cards
the xfx r9 280x double dissipation
and the sapphire r9 380 NITRO. First one is around 199, second one is around 219. I cannot chose between those two because there are inconsistencies with frame rates in different games.
Both cards run games good at 1080, however there are games such as witcher, that run at about 30fps when on high. If you want 60fps iun games like those, then go with a card around the 320 price range.
I have a pc with similar specs but with a XFX Radeon R9 280X and i can run most games on best settings at around 50 frames if not more (Excluding unoptimized games such as ARMA games)
