help with upgrading pc
Seriously, wait for Ryzen. You may just cry when you realize it's released. Info so far shows it will be way better for budget than Intel and way better performer.
Wait a while, Ryzen will make it worth it.
upgrade if you can afford it, the fx 8350 paired with a 1070 is a HUGE bottleneck. 1050 ti's tend to bottleneck the fx 8350 (personal experience) Anyways Intel is never a bad choice but Ryzen looks promising. Sadly if you want a lower end cheaper Ryzen CPU you will have to wait till Q2 which is a whiles away. If you go for that i5 7500 you will need a 1151 socket motherboard, I'd recommend a b250 or a H270 Don't get a z270 unless you go with a K processor.
yeah i wasn't sure, my friend has an intel i5 4xxx (not sure the numbers) and her computer runs games like GTA V better than mine but I know its because the 8350 bottlenecks the 1070. Is there any info on when the cheaper zen processors will be coming out?
Well AMD says later in 2017... I am guessing it will be in October-November. Although I'm not sure.
alright thanks, glad i didnt make the mistake of switching to intel
Haha, you're welcome.
