Help with USB case problem
Vicpdx17
122
So I have a Antec sonata iii case that has 2 usb ports in the front. the problem is that when I input the western digital hard drive into the second one it has to lean to the side to get my hard drive to power on. Also when I use the first one it it will barley recognize my hard drive.
I tested this out on a HP machine and when I put it straight in it the hard drive powered up without a problem.
Would this mean the usb ports are going out? if so how do you get them fixed?
clutchc
Herald
Sounds like the ports may have poor connections or defective contacts. To be sure it is the ports and not the header you are plugged into on the MB, try a different header if one exists. Replacing OEM front case ports can be a headache. You may want to abandon them and add front panel USB ports with an add-on unit that mounts in a drive bay.
Similar threads
