Help with USB Devices cutting out!
Temp0raryf1le
I'm looking for assistance in fixing my USB devices. They randomly cut out on occasion, and sometimes they will shut down entirely and require a full-on system reboot.
The main problem is that my mouse will occasionally cut out for a second every thirty seconds or so. Keyboard will do this too, but much less often. On certain occasions the mouse will sometimes just completely cut out and require a minute to start working again. I also noticed that when using headphones it's possible that all the USB devices will cut out and require a full system re-boot before they start working again.
sometime high end mice and keyboards can pull to much current on the usb chipset. you may have to buy a hub or another usb card to power all of your usb devices.
Upon your suggestion I checked my power options for Windows and realized that it was on high performance. I switched it to balanced and the problem almost entirely went away. By adding the self-powered USB hub into the mix as well the problem seems to have gone away entirely. Thanks a lot for the help!
