Help With USB headset Mic
handyheath
6
Hi guys, I know this is my first post so I'm sorry that it is to ask for help.
I own a set of Turtle Beach X11 headphones that I originally bought for use with my 360. However, I discovered I could use them for PC too so I now use them primarily for teamspeak and such. To start with I had no problem setting it up: Just plugged in the USB lead, mic lead into pink jack, audio into green jack and everything worked fine without the need for drivers or any set up.
Everything has worked fine for weeks but all of a sudden my microphone is no longer detected by my PC. The headset speakers work fine, I can hear other people but they cant hear me. The weird thing is I can hear myself speak through the speakers when i speak into the mic, so clearly it isnt a hardware issue but something else has changed by itself.
The only thing I did before the mic stopped working (Aside from use teamspeak like normal) was to install hamachi and to try and use the STEAM voice chat feature, out of curiosity. I first assumed that one of these had maybe interfered so I did a rollback but that didnt help.
I have tried all the basic stuff and am pretty sure my sound card drivers are up to date that I know of but any help would be very much appreciated.
Here is a dxdiag just in case it helps:
System Information
Time of this report: 1/19/2011, 15:53:24
Machine name:
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.100427-1636)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, MMX, 3DNow (2 CPUs), ~2.8GHz
Memory: 2046MB RAM
Page File: 752MB used, 5205MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9600 GT
Manufacturer: NVIDIA
Chip type: GeForce 9600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0622&SUBSYS_238B1682&REV_A1
Display Memory: 512.0 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor: HP 2009 Series Wide LCD Monitor
Monitor Max Res: 1600,900
Driver Name: nv4_disp.dll
Driver Version: 6.14.0012.5896 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 7/9/2010 22:38:00, 6343040 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 7/9/2010 22:38:00, 10604128 bytes
Device Identifier: {D7B71E3E-4562-11CF-3A62-870300C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0622
SubSys ID: 0x238B1682
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: C-Media CM6501 Like Sound Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\Vid_0d8c&Pid_0201&Rev_0010&MI_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: c6501.sys
Driver Version: 5.12.0008.1803 (English)
WHQL Logo'd: n/a
Date and Size: 7/10/2007 01:42:32, 1310720 bytes
Other Files:
Driver Provider: C-Media Inc.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
C-Media CM6501 Like Sound Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC517
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x005A
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 18:45:37, 59520 bytes
| Driver: usbd.sys, 2/28/2006 12:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ PS/2 Keyboard
| Matching Device ID: *pnp0303
| Upper Filters: L8042Kbd
| Service: i8042prt
| Driver: i8042prt.sys, 4/13/2008 18:18:00, 52480 bytes
| Driver: kbdclass.sys, 4/13/2008 17:39:48, 24576 bytes
| Driver: L8042Kbd.sys, 4/11/2007 14:32:30, 20496 bytes
+ Logitech HID-Compliant Keyboard
| Matching Device ID: hid\vid_046d&pid_c517&mi_00
| Lower Filters: LHidFilt
| Service: kbdhid
| Driver: kbdhid.sys, 4/13/2008 18:39:48, 14592 bytes
| Driver: LHidFilt.Sys, 4/11/2007 14:32:52, 34832 bytes
| Driver: WdfCoInstaller01005.dll, 4/11/2007 14:33:20, 1419024 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 00:13:20, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Upper Filters: L8042mou, LMouKE
| Service: i8042prt
| Driver: mouclass.sys, 4/13/2008 17:39:48, 23040 bytes
| Driver: L8042mou.Sys, 4/11/2007 14:32:38, 63248 bytes
| Driver: LMouKE.Sys, 4/11/2007 14:33:06, 79376 bytes
| Driver: KHALMNPR.Exe, 4/11/2007 14:32:22, 56080 bytes
+ Logitech HID-compliant Cordless Mouse
| Matching Device ID: hid\vid_046d&pid_c517&mi_01&col01
| Upper Filters: LMouFilt
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
| Driver: LMouFilt.Sys, 4/11/2007 14:32:58, 36112 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Failed gracefully
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Heroes of Might and Magic III (DX7) - Registry: OK, ExeFile: Heroes3.icd (<File Missing>)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 16.4 GB
Total Space: 238.5 GB
File System: NTFS
Model: ST325041 0AS SCSI Disk Device
Drive: G:
Free Space: 170.9 GB
Total Space: 476.9 GB
File System: NTFS
Model: Seagate Portable USB Device
Drive: D:
Model: AOPEN COM5232/AAH
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 18:40:46, 62976 bytes
Drive: E:
Model: CHSPUDQ E3G5UJ0P SCSI CdRom Device
System Devices
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&15B9AB7D&0&0848
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 18:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 18:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 18:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 18:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: NVIDIA GeForce 9600 GT
Device ID: PCI\VEN_10DE&DEV_0622&SUBSYS_238B1682&REV_A1\4&243D7BD0&0&0070
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 139776 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/9/2010 22:38:00, 232968 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 10604128 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 1.00.0000.0000 (English), 7/9/2010 22:38:00, 61440 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 6343040 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 1388544 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 10260480 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 4595712 bytes
Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 2506344 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 2914408 bytes
Driver: C:\WINDOWS\system32\nvdata.bin, 7/9/2010 22:38:00, 2195030 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 7/9/2010 22:38:00, 7959 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0012.5896 (English), 7/9/2010 22:38:00, 13549568 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 7/9/2010 22:38:00, 25836 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0062.0040 (English), 7/9/2010 22:38:00, 604776 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.09.0022.0107 (English), 7/9/2010 22:38:00, 236136 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.09.0022.0107 (English), 7/9/2010 22:38:00, 236136 bytes
Name: nForce HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_005E&SUBSYS_815A1043&REV_A3\3&2411E6FE&0&00
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_F3\3&2411E6FE&0&68
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 17:36:44, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_F3\3&2411E6FE&0&60
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_F3\3&2411E6FE&0&58
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&70
Name: PCI Standard-PCI-zu-PCI-Brücke
Device ID: PCI\VEN_10DE&DEV_005C&SUBSYS_00000000&REV_F2\3&2411E6FE&0&48
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005B&SUBSYS_815A1043&REV_A3\3&2411E6FE&0&11
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 18:45:35, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 18:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 00:12:08, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 18:45:37, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 00:11:54, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005A&SUBSYS_815A1043&REV_A2\3&2411E6FE&0&10
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/13/2008 18:45:35, 17152 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0057&SUBSYS_812A1043&REV_F3\3&2411E6FE&0&50
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0001.6789 (English), 8/1/2008 10:36:00, 22016 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0002.6789 (English), 8/1/2008 10:35:00, 955520 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.6789 (English), 8/1/2008 10:34:00, 9216 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.6789 (English), 8/1/2008 10:34:00, 9216 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.03.0003.0027 (English), 7/29/2008 12:33:00, 122880 bytes
Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_0055&SUBSYS_815A1043&REV_F3\3&2411E6FE&0&40
Driver: C:\WINDOWS\system32\DRIVERS\nvgts.sys, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 145952 bytes
Driver: C:\WINDOWS\system32\nvraidco.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 372256 bytes
Driver: C:\WINDOWS\system32\nvraiins.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 372256 bytes
Driver: C:\WINDOWS\system32\NvRCoAr.dll, 10.03.0000.0042 (Arabic), 8/18/2008 17:54:00, 15904 bytes
Driver: C:\WINDOWS\system32\NvRCoCs.dll, 10.03.0000.0042 (Czech), 8/18/2008 17:54:00, 15904 bytes
Driver: C:\WINDOWS\system32\NvRCoDa.dll, 10.03.0000.0042 (Danish), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoDe.dll, 10.03.0000.0042 (German), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoEl.dll, 10.03.0000.0042 (Greek), 8/18/2008 17:54:00, 16928 bytes
Driver: C:\WINDOWS\system32\NvRCoEng.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 15904 bytes
Driver: C:\WINDOWS\system32\NvRCoENU.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 15904 bytes
Driver: C:\WINDOWS\system32\NvRCoEs.dll, 10.03.0000.0042 (Spanish), 8/18/2008 17:54:00, 16928 bytes
Driver: C:\WINDOWS\system32\NvRCoEsm.dll, 10.03.0000.0042 (Spanish), 8/18/2008 17:54:00, 16928 bytes
Driver: C:\WINDOWS\system32\NvRCoFi.dll, 10.03.0000.0042 (Finnish), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoFr.dll, 10.03.0000.0042 (French), 8/18/2008 17:54:00, 16928 bytes
Driver: C:\WINDOWS\system32\NvRCoHe.dll, 10.03.0000.0042 (Hebrew), 8/18/2008 17:54:00, 15392 bytes
Driver: C:\WINDOWS\system32\NvRCoHu.dll, 10.03.0000.0042 (Hungarian), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoIt.dll, 10.03.0000.0042 (Italian), 8/18/2008 17:54:00, 16928 bytes
Driver: C:\WINDOWS\system32\NvRCoJa.dll, 10.03.0000.0042 (Japanese), 8/18/2008 17:54:00, 14880 bytes
Driver: C:\WINDOWS\system32\NvRCoKo.dll, 10.03.0000.0042 (Korean), 8/18/2008 17:54:00, 14368 bytes
Driver: C:\WINDOWS\system32\NvRCoNl.dll, 10.03.0000.0042 (Dutch), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoNo.dll, 10.03.0000.0042 (Norwegian (Bokmål)), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoPl.dll, 10.03.0000.0042 (Polish), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoPt.dll, 10.03.0000.0042 (Portuguese), 8/18/2008 17:54:00, 16928 bytes
Driver: C:\WINDOWS\system32\NvRCoPtb.dll, 10.03.0000.0042 (Portuguese), 8/18/2008 17:54:00, 16928 bytes
Driver: C:\WINDOWS\system32\NvRCoRu.dll, 10.03.0000.0042 (Russian), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoSk.dll, 10.03.0000.0042 (Slovak), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoSl.dll, 10.03.0000.0042 (Slovenian), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoSv.dll, 10.03.0000.0042 (Swedish), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoTh.dll, 10.03.0000.0042 (Thai), 8/18/2008 17:54:00, 15904 bytes
Driver: C:\WINDOWS\system32\NvRCoTr.dll, 10.03.0000.0042 (Turkish), 8/18/2008 17:54:00, 16416 bytes
Driver: C:\WINDOWS\system32\NvRCoZhc.dll, 10.03.0000.0042 (Chinese), 8/18/2008 17:54:00, 13856 bytes
Driver: C:\WINDOWS\system32\NvRCoZht.dll, 10.03.0000.0042 (Chinese), 8/18/2008 17:54:00, 13856 bytes
Device ID: PCI\VEN_10DE&DEV_0054&SUBSYS_815A1043&REV_F3\3&2411E6FE&0&38
Name: NVIDIA nForce4 Parallel ATA Controller
Device ID: PCI\VEN_10DE&DEV_0053&SUBSYS_815A1043&REV_F2\3&2411E6FE&0&30
Driver: C:\WINDOWS\system32\DRIVERS\nvata.sys, 5.10.2600.0666 (English), 4/24/2006 09:52:28, 100736 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 5/17/2005 10:45:10, 300032 bytes
Driver: C:\WINDOWS\system32\idecoiins.dll, 1.00.0000.0001 (English), 5/17/2005 10:45:10, 300032 bytes
Driver: C:\WINDOWS\system32\NVCOI.DLL, 1.00.0000.0035 (English), 4/14/2006 06:01:20, 35840 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0052&SUBSYS_815A1043&REV_A2\3&2411E6FE&0&09
Driver: C:\WINDOWS\system32\NVCOSMB.DLL, 1.03.0004.0028 (English), 8/20/2008 17:35:00, 122880 bytes
Driver: C:\WINDOWS\system32\nvusmb.exe, 1.03.0016.0001 (English), 8/20/2008 17:35:00, 453152 bytes
Driver: C:\WINDOWS\system32\nvsmb.nvu, 8/19/2008 10:41:00, 2344 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0050&SUBSYS_00000000&REV_F3\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 18:36:41, 37248 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:51 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:51 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:51 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:51 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:51 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:51 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 2/28/2006 12:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 2/28/2006 12:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:17 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:17 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:20 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:19 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:18 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 2/28/2006 12:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:41 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 2/28/2006 12:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:02 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 82432 bytes
system.dll: 1.01.4322.2470 English Final Retail 10/7/2010 02:00:45 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 1/13/2011 21:15:08 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 1/13/2011 21:15:05 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 1/13/2011 21:15:06 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 1/13/2011 21:15:06 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 1/13/2011 21:15:06 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 1/13/2011 21:15:06 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 1/13/2011 21:15:06 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 1/13/2011 21:15:07 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 1/13/2011 21:15:07 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 1/13/2011 21:15:07 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 1/13/2011 21:15:09 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 1/13/2011 21:15:09 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 1/13/2011 21:15:09 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 1/13/2011 21:15:09 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 1/13/2011 21:15:09 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 1/13/2011 21:15:08 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 1/13/2011 21:15:08 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 1/13/2011 21:15:08 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:52 2113536 bytes
mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 06:53:25 954368 bytes
mfc42.dll: 6.02.8073.0000 English Final Retail 9/18/2010 06:53:25 974848 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 00:12:10 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:11:49 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:11:51 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 00:11:52 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:11:56 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 00:12:42 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:11:59 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:53 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:12:03 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:12:03 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:12:03 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:12:03 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 17:21:32 733696 bytes
quartz.dll: 6.05.2600.5933 English Final Retail 2/5/2010 18:27:45 1291776 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 08:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 00:12:42 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 00:12:42 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 00:11:55 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 00:11:55 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 00:11:55 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 00:11:55 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 00:11:55 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 00:12:42 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 09:01:48 204800 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:16:36 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:42 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:11:56 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/13/2008 18:45:15 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 18:39:50 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 18:39:51 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 18:39:52 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 4/13/2008 18:39:53 4352 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/11/2002 23:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 03:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 03:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 03:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 14848 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 00:12:42 118272 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 14976 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 00:12:01 1428992 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:38 16384 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:42 30208 bytes
msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 17:11:44 17920 bytes
kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 15:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 03:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 03:26:40 18688 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 00:12:10 50688 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 03:26:38 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0005.0830
MXMuxFilter,0x00200000,2,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0007.3064
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5933
Wav Source Filter,0x00400000,0,1,,
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3064
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0007.3064
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
HH Multi Step Renderer,0x00200000,1,0,,
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5933
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5933
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5933
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5933
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.09.0000.0311
MPC - MPEG-2 Video Decoder (Gabest),0x00500001,1,1,Mpeg2DecFilter.ax,1.03.1264.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
MAGIX Screen Capture,0x00200000,0,1,,
MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.03.1264.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5933
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5933
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Video Source Filter,0x00400000,0,1,,
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.09.0042.0001
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.09.0042.0001
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
Xvid MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5933
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5933
FinePix Color Filter,0x00200000,1,1,FxColorFt.ax,1.00.0000.0000
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5933
Haali Video Renderer,0x00200000,1,0,dxr.dll,
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MAGIX DV Patcher,0x00200000,1,1,,
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
GrabFrame,0x00200000,1,1,,
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.09.0042.0001
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.03.1264.0000
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.03.1264.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.09.0042.0001
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5933
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
HH-DV-Pin Tee,0x00200000,1,1,,
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0007.3064
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.2600.5512
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.03.1264.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
MAGIX Renderer Connector,0x00200000,1,1,,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Fujifilm Setup Filter,0x00200000,1,1,FujifilmSetupFilter.ax,0.04.0000.0005
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5933
Magix DS Capture,0x00200000,2,0,,
MAGIX StreamWriter,0x00200000,1,0,,
MAGIX MuxWriter,0x00200000,2,0,,
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5933
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5933
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3064
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5933
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5933
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5933
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Magix WAV Dest,0x00200000,0,0,,
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.09.0042.0001
HH Multi Source Filter,0x00400000,0,1,,
FinePix Rotate Filter,0x00200000,1,1,FxRotateFt.ax,1.00.0000.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5933
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0007.3064
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5933
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX 5.0.5 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
MainConcept DV Codec 2.0.4,0x00200000,1,1,qcap.dll,6.05.2600.5512
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V3,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5933
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5933
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5933
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5933
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5933
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5933
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.5933
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5933
SHARP G.726,0x00200000,1,1,quartz.dll,6.05.2600.5933
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
NCT ALF2 CD,0x00200000,1,1,quartz.dll,6.05.2600.5933
AC-3 ACM Decompressor,0x00200000,1,1,quartz.dll,6.05.2600.5933
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5933
Audio Capture Sources:
C-Media CM6501 Like Sound Devic,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5933
WDM Streaming Capture Devices:
C-Media CM6501 Like Sound Device,0x00200000,3,3,,5.03.2600.5512
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
C-Media CM6501 Like Sound Devic,0x00200000,1,0,quartz.dll,6.05.2600.5933
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5933
DirectSound: C-Media CM6501 Like Sound Device,0x00200000,1,0,quartz.dll,6.05.2600.5933
WDM Streaming System Devices:
C-Media CM6501 Like Sound Device,0x00200000,7,2,,5.03.2600.5512
it really sounds like your microphone is no longer selected in the audio properties.
i have windows xp and there have been times when i select 'microphone' in the soundcard software.. but it doesnt work because a different recording device is selected in the audio control panel.
i have to go to start/control panel/sound and audio devices/audio tab/sound recording .. then select the appropriate device.
there is also another place to change the recording input.
its a different tab.
start/control panel/sound and audio devices/voice tab/voice playback .. then select the appropriate device under 'default device'
IF that doesnt work..
maybe you have to select the microphone with the windows mixer.
that is start/control panel/sound and audio devices/volume tab/device volume/advanced
a window pops up with a bunch of volume bars.
press 'options'
select 'properties' from the drop down.
make sure your soundcard is selected for 'mixer device' and select 'record' from the 'adjust volume for' section.
you will see the list change down below.
make sure all of them have a check mark and press ok.
now you should be looking at all of your recording options.
find the one that says 'microphone' and tick the box at the bottom of the volume slider.
that will select the microphone to be used for recording.
and if you want to stop hearing yourself talk when you speak into the microphone.. you have to mute it.
to do that you go start/control panel/audio and sound devices/device volume/advanced/options/properties/playback
make sure all of the boxes have a checkmark and press ok.
a new window pops up showing you all of the volume sliders for playback.
find the one that says 'microphone' and tick the box next to mute.
this will still allow you to speak into the microphone and be heard by other people.. you simply wont hear your voice over your speakers anymore.
and if none of that works.. try reinstalling the soundcard drivers.
if that doesnt work.. its time to erase the hard drive and reinstall the operating system.
i apologize if you are using a different operating system.
i dont know how to navigate through those operating sytems.
but its quite the same, just different names.
Thanks for the reply, really appreciate the time you took to help. Unfortunately I have already taken all the measures suggested. My sound card (C-Media CM6501 like sound device) is the only option available for mixer device and so i have that selected. Microphone is also selected for the recording option both on the windows menu and on the c-media utility program for my Sound card.
I would try updating/reinstalling my sound card's drivers but I havent been able to find a working link to any drivers.
My exact Sound card model is C-Media CM6501 like sound device, which is just an onboard sound card for the Asus M2N-E SLI motherboard i think. My current driver version is 5.12.0008.1803, dated to 10/07/2007.
As far as I can tell this is also the most up to date driver for windows XP.
I didnt think it would be a problem with my sound card or driver since all other aspects of audio work fine, just the microphone that wont work.
If anyone can point me towards a working driver for this card or give any other suggestions I would love you long time.
asus has these drivers available for download:
Version 5.12.8.709&5.12.8.1606
V5.12.8.1802
Version 5.12.2.4219
as you said.. the microphone works because you can hear yourself talking in the headphones.
nothing else to blame except for software that isnt working to support the functionality.
lots of hardware out there that can run on other drivers.
sometimes you just gotta add your device to the list of supported hardware in a configuration file.
what else is there to say other than malware or you've been hacked..?
have you actually tried changing something and then putting it back?
because sometimes a program will say it has something selected, but the registry settings will say something entirely different.
sometimes the most up to date driver isnt the best solution.
I tried a few different drivers but none seem to work. I have pretty good antivirus software and if someone hacked me im sure theyd do more than mess around with my sound settings.
Say I wanted to buy a new sound card and install on my machine, would any card be compatible? and how would i go about disabling my motherboard's on board sound card?
the other drivers didnt install .. or they didnt fix the problem?
most of the soundcards on the market today are PCI
that means they plug into the PCI slot.
all motherboards have PCI slots.. it just depends on whether you have one that is empty.
getting a new soundcard isnt difficult to do.
searching for the right soundcard is harder than plugging it in..!
if you can plug in a lamp or television or phone cord.. or even a charger on a phone - you can plug in a soundcard.
you should use a little bit more care to keep the card straight with the socket.. because it is a tight fit and doesnt allow much to be wrong with the angle.
i suppose people are scared because it takes a bit of force to plug something in.. but that is the nature of the socket.
its a tight fit because the slot is reading from pins and they have to make contact with eachother to work.
i'm not really trying to imply that you get a new soundcard, because the one you have is supposed to work.
but i wouldnt hold doubt to malware changing something.
it is the job of malware to be annoying.
and it is the job of a virus to damage data.
the annoyances usually come at random and its not like you were selected and had some hacker manually trying to upload an annoyance.
that stuff is usually automated.
anyways.. if the other drivers installed, but didnt fix the problem, you have a problem obviously.. and i would be leaning towards software as the cause.
you do know that it takes less than an hour to reinstall the operating system dont you?
its very easy to do if you have the disc because there are instructions on the screen.
the only severe problem that is often occuring is the fact that if you have your hard drives in a RAID configuration.. you have to feed the operating system those RAID drivers from a floppy drive before the installation can start.
i think a PC technician would try to work with the drivers and make sure all of the registry settings are properly set.
and that might fix the problem before needing to move on.
but if it doesnt, they would reinstall the operating system to see if that helps.
and if that doesnt work, they would either try to diagnose the electrical components of the soundcard .. or they would simply say that its broken.
there are some benefits to using an aftermarket soundcard.
the biggest one is the fact that a quality soundcard will have its own processor .. which takes the load off of your main processor.
you can then look at features the soundcard has to really make the change more enjoyable.
things like virtual surround and/or dolby decoding for movies.. these two should be the biggest concerns.
then a much needed time alignment of the audio if you are not using headphones.
is there any way you can test the headphones and mic on a different computer?
i am just trying to rule out a problem with the microphone actually sending data to the computer.. or is the little amplifier in the cord malfunctioning?
to do that, you would need to plug the microphone into something else.. or get something else to plug into the microphone input of the soundcard.
you can use headphones as a microphone.. but you have to put your mouth right up to the headphone speaker because the headphones arent sensitive enough.
simply using the 'sound recorder' program that comes with windows would work to record something plugged into the microphone jack on the soundcard.. then play the recording back to listen for anything.
to disable the onboard soundcard, there should be an option in the BIOS of the motherboard.
you enter the BIOS after you start the computer, before the operating system starts to load.
usually there is instructions on the screen telling you to push F8 or the delete key to enter BIOS.
Wow anywaypasible, truly grateful for the very informative replies have taken the time to give me, I salute you sir 😉
I got a friend who is a little more tech savvy to reinstall my OS, which didnt work initially but then after restarting my comp a few times it decided it would like to let my mic work again :heink: I cant explain it, its like it has a mind of its own but ah well, it is now fixed so i will not complain.
Once again thanks for being patient and offering so much help. I would give a million thumbs up if i could.
