Question Help with using a proprietary board ?
Dec 31, 2021
I have got a ASUS H81 M70AD which is a proprietary board, size wise its mATX so thats fine but im not sure what adapter I have to use to connect it to a standard aftermarket PSU.
What prebuilt did you remove the board from? I'm seeing on Google that it should be out of an Acer prebuilt, though no mention of the prebuilt's SKU, in order to identify the PSU used. Due to the connectors the PSU is proprietary and as such if you're handy with a multimeter you can identify the power inputs to fabricate your won set of harnesses.
You could contact Moddiy and see if they can turn up any leads but I'd avoid tinkering with the board if you can't find the right harness for it or you want to drop in a discrete GPU in the system to "game" on since the prebuilt was not designed with what you want to do, in their design process.
