Help with using SSD and HDD together
Ryan Anderson
4
Hi, I'm pretty much a noob with hardware stuff and I wanted to know if I can install windows on an SSD and use the HDD as my main memory disk.
thank you all.
Hi there @Ryan!
Setting your SSD and HDD together in the same computer isn't a hard thing to do. You just have to:
1. First Plug the SSD only
2. Install Windows on it
3. Then plug your HDD
4. Initialize and format it as well.
After you do that you should have C: and D: drive (the SSD and HDD respectively).
I think that this video could be quite helpful to you as well:
https://www.youtube.com/watch?v=qMo8krAJd5Q
Cheers! :)
