Help with videocard.
Jinkens
14
I just installed my computer everthing powering up but it doesn't seem to send anything to my monitor tried with 2 different monitors. The video card is working since it's fans starts the second the monitor is inserted.
PSU: 560W brand new PSU with ATX2.0
RAM: 3GB 667 DDR2 RAM
Motherboard: MSI P965 NEO-F S-775
HD: 160GB Hitachi 7200rpm SATA2
GPU: 1GB HIS Radeon ATI HD4870
CPU: Intel Core 2Quard Q6600 2.40GHz 8MB S-775
DVD-ROM: 18x LG DVD/RW Dual Layer
Jinkens
14
Yea both connected and they are connected correctly. even tried with my spare to see if one of them were somehow broken.
Does the computer POST.
if the little case speaker is connected it gives a single beep if it has started properly . If there are faults they produce various beep codes .
so does it POST?
is the monitor plugged in and turned on?
Jinkens
14
I just tried booting it with my headset plugged in for trying to hear the sound but there were no sound at all.
Jinkens
14
Ohh missread your post. Well no it doesnt make a sound when i boot it.
and yea the monitor was plugged in and truned on. Both i tried with.
MSI doesn't use beep codes. There should've been a led bracket that came with the board with 4 lights on the back. This will give you a diagnostic light code.
You can try pushing down on the video card to make sure it's seated all the way. But you should hook up that bracket and get the code.
Jinkens
14
The flaw in that is the computer isn't exactly homebuild. It came with everything in it just started acting wierd so if it's something not mounted on the mobo as standard i might not have it.
