G
Guest
Guest
Archived from groups: alt.games.vga-planets (More info?)
I haven't been able to process my latest turn files using vpa. The
only thing different about the current turn files is that I received
wormhole messages from Animal Tech games Worm program. Unfortunately
the message generated by the add on does not match the message
template in the vpa.msg file. Since my game seems to freeze upon
attempting to read the player messages I think these wormhole messages
are the problem. Question- has anyone created a vpa message template
for these particular wormhole messages? Can you provide the template
so I can run the turn ?
; *** Wormhole
Message Wormhole
;Check 1,[Sub Space Message]
;Check 3,1,From
Check [Our scanners detected a wormhole]
Id [(ID #],[ID #],[)]
X [at location],[location]
Y [at location],[,,],[(]
Mass [Appears],[at:],[KT]
Stable [Appears],[Appears]
;Mass [in size],[is],[KT]
;Stable [appears to be],[appears to be]
End
; *** Wormhole
Message Wormhole
;Check 3,1,From
End
