Help With Wall Mounting
ExoticAzule
110
Hello all!
I need help finding a good strong, sturdy, and flexiblish wall mount for the Z35P, I believe the Z35P is a 100x100mm vesa mount. All the wall mounts I’ve found that are 100x100 are meant for TV’s and I’m not sure if they would work the Z35P.
Thanks!
does not matter.
as long as the mounting holes fit you are good.
tv's and monitors weigh nothing and the mount can handle the display
