M momo eric Honorable Oct 23, 2014 389 0 10,860 Feb 20, 2015 #1 hello , i m new to water cooling and i wanna try it out as they look freaking awesome . i wanted to know that if it was better to buy full set like that of thermaltake kits , or buy different parts separately . thank u .
Solution Zerk2012 Feb 20, 2015 Actually their nothing wrong with kits if you get the right kind and a TT kit is not the right kind. Something more like this. http://www.frozencpu.com/products/24956/ex-wat-318/EK_X360_Complete_Triple_120mm_Liquid_Cooling_Kit_EK-KIT_X360.html?tl=g30c321 Depending on your PC as what you need.
4745454b Retired Mod Apr 29, 2006 29,244 449 93,590 Feb 20, 2015 #2 Best performing will be parts you research and buy separately. Easiest will be full kits. Upvote 0 Downvote
M momo eric Honorable Oct 23, 2014 389 0 10,860 Feb 20, 2015 #3 are these parts available in pcpartpacker or newegg Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,334 2,408 104,240 Feb 20, 2015 Solution #4 Actually their nothing wrong with kits if you get the right kind and a TT kit is not the right kind. Something more like this. http://www.frozencpu.com/products/24956/ex-wat-318/EK_X360_Complete_Triple_120mm_Liquid_Cooling_Kit_EK-KIT_X360.html?tl=g30c321 Depending on your PC as what you need. Upvote 0 Downvote Solution
