hello there folks, i have a self built computer wich is alright now; (plz dont judge my english, i am from norway, and some words might just not pop into my head correctly sometimes)
intel core i5-3350p
asrock z75 pro3 (i think, cant remeber quite surely xD)
cm hyper 212 evo (i lost a tiny spring that is essesential, so using stock cooler now)
8gb corsair ddr3 1600mhz ram
sapphire r9 280x vapor x 3gb oc
1tb wd blue hdd
samsung 840 evo 128gb ssd
cm 690 II advanced
so i feel like this 3nd generation ive bridge cpu is hold back some of the performance, or might be a problem in the future. i am getting an i5 4690k with the asus z97a and a nzxt source s340.
the source case has a window, and i though, maby that hyper 212 evo will look ugly in that case, and i am getting a k cpu for overclocking, so i might just get a mid range water coller right? for the look and the efficiency. Now there are kinda 3 possible outcomes here. I ask and get a spare part for the 212, or i have to buy a new 212 because they dident have a spare part. Or i go for watercooling.
I have seen the poseidon from coolermaster, and it is about 10-13 dollars more than a 212. which quiet and efficient water cooler can i get for under 90 dollars, and is it worth it for the looks? (Taxes makes prices alittle different than if i would convert usd to nok, something cost 80 in the states, and same thing could maybe cost about 100 dollar here in norway
intel core i5-3350p
1tb wd blue hdd
cm 690 II advanced
