One day when I went to boot my PC I encountered a problem. The power light turned on, all the fans spooled up, but there was no output to my display and my keyboard only turned on for a few seconds then went black (at least the backlighting did). When I pushed the power button again the PC immediately shut off, I didn't have to hold it down at all.
I immediately did the stuff all the forums say: tried each RAM stick separately, tried to boot with the GPU uninstalled, did a CMOS reset, I basically took it apart and put it together again. And it started! ONCE. I got it back to the desktop, did some web browsing, played a bit of Fallout 4, and then hit a solid blue screen freeze. And then it refused to start again. Every time the keyboard would flash on for a few seconds and then turn off, while all the fans kept spinning and the HDD spooled up.
So, I decided to replace the PSU (mostly because the motherboard was no longer widely available and anything else would have basically meant building a new system from scratch). I took the PC apart, installed the new PSU and reconnected everything. And it started right up! This time it started to the BIOS setup screen, so I clicked through and it finished booting to the desktop. Everything was peachy, I ran a few programs, watched some videos, played some games. No blue screen. I shut the PC down and then tried to start it up again. And it didn't work! Same problem. Is it the motherboard? I really hope its not the motherboard. I think its probably the motherboard.
System Specs:
i5 3350p
Radeon HD 7870 XT
ASRock z75 Pro3
Corsair Vengeance 2x4gb DDR3 1600
Seagate Barracuda 500 gb 7200 rpm SATA
Corsair CX500 500W 80+ Bronze
Windows 10
TL;DR: PC didn't boot, replaced PSU, booted once, now won't boot.
System Specs:
i5 3350p
Radeon HD 7870 XT
ASRock z75 Pro3
Windows 10
