help with winhlp.exe please
Paul
Splendid
Mar 30, 2004
5,267
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have been getting repeated messages along the lines of:
WINHLP1.EXE HAS CAUSED AN ILLEGAL INSTRUCTION IN NTVDM CPU
I have also found a file called winhlp.dllalias which has references to a
website called Americanfurniturewarehouse.com which repeatedly causes a
pop-up on my internet explorer. Deleting this file has no long term effect.
It just reappears.
Any ideas how to cure?
In news:F284A509-5EDB-46B0-B308-97995E70BB4C@microsoft.com,
Paul <Paul@discussions.microsoft.com> had this to say:
My reply is at the bottom of your sent message:
> to a website called Americanfurniturewarehouse.com which repeatedly
> causes a pop-up on my internet explorer. Deleting this file has no
> long term effect. It just reappears.
Sounds like you're the victim of malware...
Malware Cleaning :
http://kgiii.info/windows/all/general/malwarefix.html
Galen
"You know that a conjurer gets no credit when once he has explained his
trick; and if I show you too much of my method of working, you will
come to the conclusion that I am a very ordinary individual after all."
Sherlock Holmes
Thanks Galen. Seems to have done the trick.
> Malware Cleaning :
> Galen
> Sherlock Holmes
In news:F844C03D-E084-4067-85E7-1C7439C159BF@microsoft.com,
>> Malware Cleaning :
>> Galen
>> his trick; and if I show you too much of my method of working, you
>> will come to the conclusion that I am a very ordinary individual
>> after all."
>> Sherlock Holmes
No problem, for curiosity sake which application cleared it up and what was
the name of the malware?
Galen
Sherlock Holmes
Not sure I can answer that..
I ran the instruction 'netsh winsock reset', and that has cured the illegal
NTVDM instruction messages. I then downloaded A Squared which found a single
instance of malware... I'm afraid I deleted it without noting it down, sorry.
I also downloaded Windows Anti-Spyware (Beta), but this found nothing.
Lo and behold, American Furniure Warehouse.com has just popped up again.
I'm sure it's something to do with this winhlp.dllalais file.
I'll run all the cleaners again and see what happens...
Cheers mate
Paul
> >> Malware Cleaning :
> >> Galen
> >> after all."
> >> Sherlock Holmes
> Galen
> Sherlock Holmes
In news:7618A056-F383-4521-AE1E-675A8BF41332@microsoft.com,
> illegal NTVDM instruction messages. I then downloaded A Squared
> which found a single instance of malware... I'm afraid I deleted it
> without noting it down, sorry. I also downloaded Windows Anti-Spyware
> again.
> Cheers mate
> Paul
>>>>> references to a website called Americanfurniturewarehouse.com
>>>>> which repeatedly causes a pop-up on my internet explorer.
>>>>> Deleting this file has no long term effect. It just reappears.
>>>> Malware Cleaning :
>>>> Galen
>>>> after all."
>>>> Sherlock Holmes
>> what was the name of the malware?
>> Galen
>> will
>> all."
>> Sherlock Holmes
<g> Let me know how it turns out. I can say that I've never HEARD of a
furniture store using hijackware. That doesn't mean they don't, just means
that I've never heard of it. Make sure to delete all your temp internet
files, including offline content, and maybe your cookies too if you don't
have any special ones saved.
Galen
Sherlock Holmes
Galen,
May have cracked it. In the Advanced Tools section of Microsofts Anti
Spyware, I found an IE BHO (all new things to me) attached to winhlp32.dll.
I took up the offer of permanently blocking the BHO, and in the last 2 hours
(fingers crossed) no pop-ups.
Like you say, an unusual company. It's more often some form of porn site!
Ta,
Paul
> > again.
> > Cheers mate
> > Paul
> >>>> Malware Cleaning :
> >>>> Galen
> >>>> after all."
> >>>> Sherlock Holmes
> >> Galen
> >> will
> >> all."
> >> Sherlock Holmes
> Galen
> Sherlock Holmes
