[SOLVED] Help ~ WPS Office Can Not Print.
TechChiu1988
8
View: https://imgur.com/a/i6uHE9y
Hello I encounter this problem 2 days ago still looking for solution and i have no idea how to fix it i have try too restart the Print Spooler by stoping it and starting it in service still no luck the weird part about it other software can print or doing test print but only WPS Office can not seem to print.
Please Help ~
Well, normally I'd point to a user forum hosted by the publisher, but it doesn't seem that they have one according to a quick google search (maybe it is just hard to find?).
So instead, if this problem persists, I'd recommend switching to Libre Office.
Thanks for replying i have been searching all over google looking for solution for about this error sadly can't find any and sadly i can't seem to access wps office forum for some reason as it will show me "404 - Page Not Found" and i will try Libre Office .
Again Thanks For Reply...
never tried this with wps office but for open office and some other open source software, creating a new user and trying to print from there has worked for many people.
not sure why but somehow something in the configuration gets jacked up and a fresh user with default config works. worth a shot anyway and simple to do :)
Thanks for reply not quite sure by creating new user ? you mean i need to create new user account in windows ? sorry for bad english...
yes that's what i mean. sorry for not being more clear.
sounds odd but this has helped many people with similar issues. create a new user account in windows and try to print from there. again never tried it with wps office but i know this has worked for other programs including Microsoft office itself!!
Reactions: TechChiu1988
Ok will try Thanks for giving solution ...
