Question Help X470 Aorus ultra gaming
sif5812
12
sif5812
12
it was my graphic card, no warranty left according to newegg.
i have a deepcool 650 watts, could that be the cause of the gpu error? because there isnt a signal at all, also there was a electric storm a few weeks ago could that be also the cause of the problem.
thank you
thank you
So that's the graphics LED?
If so I would power down and reseat the GPU.
If that didn't work, I'd look at the PSU voltages with HWInfo to make sure they were in spec and I might even swap the PSU if I had suspicions.
I'd also try the GPU in another system if that was convenient.
