G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
my XP machine keeps on re-booting. it is just going on the loop. it boot
until the xp logo with progress bar then it'll reboot again and again. i have
some docs that i need to finish please help. dont know what happened. my xp
installation cd comes with sp2.
sam
G
Guest
Guest
Try a repair install as follows:
NOTE, while a repair install should leave your data files intact, if
something goes wrong during the repair install, you may be forced to start
over and do a clean install of XP. If you don't have your data backed up,
you would lose your data should that eventuality occur.
Assuming your system is set to boot from the CD-ROM drive and you have an
actual XP CD as opposed to a recovery CD, boot with the XP
CD in the drive and perform a repair install as outlined below. If the
system isn't set to boot from the CD or you are not sure, you need to enter
the system's BIOS. When you boot the system, the first screen usually has
instructions that if you wish to enter set press a specific key, when you
see that, do so. Then you will have to navigate to the boot sequence, if
the CD-ROM drive is not first line, set it first in the boot sequence. Save
your settings and exit with the XP CD in the drive. The system will reboot.
When the system boots, a few screens into the process you may see a message
instructing you
to hit any key in order to boot from the CD along with a countdown. When
you see this be sure to
hit a key on the keyboard, if you miss this instruction and the system fails
to boot from the CD, it's too
late, you'll need to reboot and try again.
Once you have pressed a key, setup should begin. You will see a reference
asking if you need to load special drivers and another notice that if you
wish to begin the ASR (Automatic Recovery Console) depress F2. Just let
setup run past all of that. It will continue to load files and drivers.
Then it will bring you to a screen. Eventually, you will come to a screen
with the option to (1) setup Windows or (2) Repair Windows Installation
using the Recovery console. ***The selection you want at this screen is
"Setup Windows,"
NOT "Repair Windows Installation.
The first option, to setup Windows is the one you want and requires you to
press enter. When asked, press F8 to accept the end user agreement. Setup
will then search for previous versions of Windows. Upon finding your
version, it will ask if you wish to Repair your current installation or
install fresh. Press R, that will run a repair installation. From there
on, follow the screens.
Note, in some cases, you won't receive the repair option, only an option to
reinstall. We have discovered that sometimes this is caused by damaged
boot.ini file that can be repaired as follows and also note, in the
instructions, "K" refers to the CD drive in which you have placed the XP CD,
replace that drive letter with the appropriate letter on your system, "K" is
simply an example.
Reboot, this time taking the immediate R option (this is the section I told
you to skip above. In this case, you will need to get to the Recovery
Console to perform the function below), and if the CD letter is say K: give
these commands
COPY K:\i386\ntldr C:
COPY K:\i386\ntdetect.com C:
(two other files needed - just in case)
ATTRIB -H -R -S C:\boot.ini
DEL C:\boot.ini
BootCfg /Rebuild
Once you've completed this function, reboot and see if you can access XP as
sometimes, the problem is the damaged boot.ini. If you still cannot access
XP, then reboot and re-run the repair install instructions at the beginning
of this message.
If you only have a recovery CD, your options are quite limited. You can
either purchase a retail version of XP which will allow you to perform the
above
among other tools and options it has or you can run your system recovery
routine with the Recovery CD which will likely wipe your drive, deleting all
files but will restore your setup to factory fresh condition.
Michael Solomon MS-MVP
Windows Shell/User
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"samrod" <samrod@discussions.microsoft.com> wrote in message
news:47393C8C-7B41-4E6E-A6BF-D3D001902A35@microsoft.com...
> have
> xp
> sam
neptune
12
Press F8 while starting up, then go through a safe-mode
remove the last driver you installed.
have
| sam
G
Guest
Guest
Or select Last Known Good Configuration at the Boot Options screens.
"Neptune" <Neptune@hotmail.com> wrote in message
news:IwQhd.47096$R05.29980@attbi_s53...
> have
> xp
> | sam
G
Guest
Guest
Just to add, if he tries "Last Known.." he must do so before entering Safe
Mode or "Save Mode" will be the "Last Known Good Configuration."
Windows Shell/User
"Colin Barnhorst" <colinbarharst(nojunk)@msn.com> wrote in message
news:OF6Pf8RwEHA.1512@TK2MSFTNGP12.phx.gbl...
>> boot
>> i
>> have
>> my xp
>> | sam
G
Guest
Guest
Hi,
If you have installed SP2, hit F8 at boot, as if you were entering Safe
mode. Then choose this option: "Disable automatic restart on system
failure", then continue the boot. This should either get you into the
system, or give you a stop error (bluse screen) that will at least tell you
what is wrong.
How to start in Safe mode:
http://www.rickrogers.org/fixes.htm#Safe%20mode
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
> have
> xp
> sam
G
Guest
Guest
Yes, don't choose Safe Mode, but choose Last Known Good Configuration
further down on the same screen.
"Michael Solomon (MS-MVP)" <user@#notme.com> wrote in message
news:%23QH$MVTwEHA.3808@TK2MSFTNGP15.phx.gbl...
> Windows Shell/User
>>> boot
>>> i
>>> have
>>> my xp
>>> | sam
