Help
  • Thread starter Thread starter Guest
  • Start date Start date
Going to need loads more details than that. Why is it not working, what does it sound like, what were you doing when it broke...
Looks like this system came with Vista, did you install Win 7 on it? You can try the Vista drivers for the audio, if that does not work, either go back to Vista or live with no sound. I'm assuming you installed Win 7 on this yourself, you need to check system compatabily before installing anything.
As jimmy22 pointed out "not working properly" is not a good way to describe an issue. Is it not working at all? Is it playing random music you don't like? Did it steal your wallet?
