Well I didnt really know where to place this post but since the game is causing the problem I will post it here.
Ok so I just built my brother a computer and everything was working fine. He bought PotC (Pirates of the Caribbean) and attpemted to install it. It got 2% through and got a CRC error. It said this file does not match the file on the CD's setup file. The medium from which you are installing from may be damaged or corrupted. It had an ignore button so I pressed that and this error came up for almost every file. The game eventually installed after ignoring every CRC Error, then when you play for about 2 seconds it restarts the whole computer. I have all the latest drivers for my Motherboard and Video Card. I have asked a Friend and he says scan for viruses but first I dont have a virus scan program, so I went to download.com to look for Norton. I found it but when I downloaded it it would not install!! What should I do to fix these CRC errors?? By the way his computer is :
Mother Board : Gigabyte GA-7AXP K7 Triton Series
Video Card : ATI Radeon 9800 Pro
CD Drive : Sony 52x/24x/42x
CPU : AMD Barton 2500+
If you need more infomation about the computer just ask.
