Help
nekkid_animal
7
Hello,
i have an asus /hp mother board with an e5300 cpu 2.6 ghz, chip. can i swap it out with a 3.40 mhz chip? the board is an ipibl-lb thank you
nna2
2,032
105
Motherboard supports the following processor upgrades:
Intel Core 2 Quad (Y) Q9xxxx
Intel Core 2 Duo (W) E8xxx
Intel Core 2 Quad (K) up to Q6600
Core 2 Duo E6x00 (C) up to E6700
Core 2 Duo E4x00 (C) up to E4400
is you CPU from one of those series? (the one you want to buy)
phyco126
1,015
69
As nna2 said, it will be a MASSIVE downgrade from what you have. I cannot stress this enough: IT. WILL. BE. A. MASSIVE. DOWNGRADE.
The E5300 is nearly, and in some cases more than, TWICE as fast as any Pentium 4 (which is the processor you have).
For more info, the processor you mention is a Pentium 4 550 3.4 GHz with Hyper-threading (http://ark.intel.com/products/27469/Intel-Pentium-4-Processor-550-supporting-HT-Technology-(1M-Cache-3_40-GHz-800-MHz-FSB))
However, that processor is 8 years old! The E5300 is much newer and much faster. Don't believe us? Check this out. This chart compares the E5300 to an 3.46 version of the Pentium 4 (http://www.anandtech.com/bench/Product/98?vs=93)
