G
Guest
Guest
Hello,
How do I find the WEP/WPA/Security Key/Password for my wireless router
That is something that has to be done dureing the router setup. Find out how to access your router configuration. It will usually be something like this http://192.168.1.1/ and for the password to access it if it hasnt been changed from the default settings will be username: admin password: admin.
moody89
799
What make and model of wireless router are you using? Make sure you have fully read the documentation that came with your router as it may be in there. I have often seen it on a sticker on the bottom of the router too. It is recommended to change it as soon as possible since the default pass keys are not difficult to compromise. Post back if you still don't have any joy and we'll go from there. Good luck!
