HELP
juanes287
23
Best answers
ive been playing half life 3 alot latly and last night my system began to freeze up for no reason. just randomly while i was playing the frame rate would slow down drasticly and make it imposssible to play. this would only last for about 10 seconds than the frame rate would jump back up.
just looking for some help plz/
kool_moo
52
Best answers
Do you mean Half-Life 2 Lost Coast? Or HL2? There is no Half-Life 3... And please list your system specs and temperatures.
juanes287
23
Best answers
half life 2 sorry,
my specs are
p4 3.0ghz 478
6800 gt oc
1 gb kinston vaulue
350 power supply
120 gb maxtor dirve
the 6800 gt runs at about 77 under heavy load
AntiHax0r
185
Best answers
Might want to take a look on the powersupply too... a little weak for a p4(prescott, im assuming here) and a geforce6800
ChipDeath
Splendid
May 16, 2002
4,307
Best answers
Why? It's not crashing. I'm getting increasingly tired of people suggesting Power supply for issues like this. Power supplies being underpowered do not cause poor performance, they cause crashes, sudden power-offs, and reboots.
If the driveshaft in a car is too thin/brittle to transfer the power from the engine to the wheels, it'll break, and all power will be lost... It'll never just give reduced performance.
Poor PSUs are responsible for many things, but poor performance isn't one of them. :roll:
Now, maybe his PSU will die relatively quickly due to the amount of load on it (I agree, it does look a little low for a scotty, but it's probably ok for a Northwood... His CPU could be either. If it's a Fortron then he'll probably be ok either way for a while..) but it's not the source of his immediate problem. If you can find a single verified situation where this is the case, then I'll gladly concede the point.
juanes287:
My thoughts on the problem? Either throttling, or some background process (Virus scan, messenger, etc) momentarily trying to grab system time for some reason. Make sure to shutdown everything in the background that you can, and do a spyware/Adware scan, just in case.
mpjesse
Splendid
Dec 31, 2007
7,214
Best answers
6
Right on. I'm getting tired of it too. I read a post somewhere in here yesterday where a guy said that the powersupply is THE most important piece of equipment in a computer. LOL.
-mpjesse
kmac20
23
Best answers
-mpjesse
Thats because it is. Can you use a PC without a powersupply?
WOWchamp
228
Best answers
Powersupply does seem a bit low... but as not good as it is it shouldnt cause these problems. Try to return your OC's back to stock and see what happens.... if nothing try better cooling options.
tylerthedruid
118
Best answers
hey tyler hows juanes's mom is she good at it or has all the prostitution taken a toll?
rofl. You know, I was surprised to find that she's quite adept at playing halo 2. Never would have thought. I don't think it's the prostitution that took it's toll; the other day she said 'left home country, son embarrass family, try to put goat into computer, keep say he is hacksohr'
And we all know the CDrom drive is the most important part of the computer.
By the way, where can I find info on how to calculate how much power you can put on all the rails of the PSU? I barely remember the TEC101 explanation of watts, volts, resistance, etc.
dvdpiddy
Splendid
Feb 3, 2006
4,764
Best answers
1.lol
2.dont know
3.tyler where you been?
bombasschicken
192
Best answers
no man you got is all wrong.. its the on/off button on the monitor.. without that nothing would work.. i once broke the button on my monitor and had to buy a whole new computer cause it was dead i think.. at least thats what the computer sales man told me.. and we always listen to thoes guys right???
dvdpiddy
Splendid
Feb 3, 2006
4,764
Best answers
i'm going to talk in binary now
01101010 01110101 01100001 01101110 01100101 01110011 00110010 00111000 00110111 00100000 01101001 01110011 00100000 01100001 01101110 00100000 01100001 01110011 01110011 01101000 01101111 01101100 01100101 try and figure it out juanes
cisco
719
Best answers
I would check the heat sink and make sure there is not dust in it. A dusty heat sink will heat the gpu up and then it will slow down. Also check all your case intake fans make sure they are clean as well. Reduced air flow in the case itself can cause it as well.
linux_0
Splendid
Dec 18, 2005
5,314
Best answers
34
For those that are binary impared this means:
juanes287 is an ???????
FlyGuy
461
Best answers
Why is that so funny? The PSU powers every component in your machine so wouldn't it stand to reason that it's one of if the the most important components?
