Question Help!
Oct 24, 2015
155
6
4,595
If a mobo writes they are compatible with rams between 2133 and 2933mhz ddr4, does it match with all of them? Is it possible for ram to be 2133 +ddr4 and not match it? Help I need to customise the order ASAP
2133 -2933mhz is the speed the ram will work, so you can buy 2133,2400, 2600 ,2800, and even 3000(Kinda the same 2933 ). If the memory is DDR4 no matter the speed, it's going to work, you can even buy a 3600mhz memory and they will still work, but at the limit speed of 2933-3000.
If you tell us the Motherboard + Memory you're planning to buy, or if you have a budget we can help you find the best combo to match.
