Question Help!
Jul 23, 2019
8
So i bouth new asrock b450m-hdv r4.0 mothervoard with ryzen 5 2600x, when i loud up a game like cs go, and load a map the pc turns off, or the cpu fan starts spining like crazy and pc turns off, what ist the problem and how to fix it? Ram:G-skill trident z 3200, cpu coller: wraith, and gpu: Rx580
Jul 23, 2019
8
While I suspect power supply, or temps, we need full system specs, including make/model, of the power supply.
psu: chieftech 750w-14cs, cpu:ryzen 5 2600x, motherboard :asrock b450m-hdv r4.0, 16g of G-skill trident z ram, gpu: asus dual Rx580, 240g kingston ssd, and toshiba 1T hard drive.
jeremyj_83
Estimable
At best that PSU is based on a design well over a decade old and shouldn't be used in a modern system. Are you able to tell us what your CPU and GPU temps are when you start gaming? Are you doing any overclocking on your system?
Jul 23, 2019
8
No oc, i cant check any tems because after 5 sec computer chuts down
jeremyj_83
Estimable
well im getting 1.4, 1.39 Voltage on windows
The voltage should automatically change if it is set to Auto in BIOS depending on the boost of the CPU. However, if your computer is running at that high of a voltage at idle that seems a bit odd. It could be that your PSU isn't able to supply the power needed reliably and needs to run at a higher voltage to be stable.
Jul 23, 2019
8
well it doesn let my share pictures, i did ss ryzen master
