That, and have a decent quality 450W PSU (or better).Is that all i have to do
I only have the motherDo you have the motherboard already with a working 1st gen cpu to perform the update or are you looking into buying?
Board right now im looking into upgrading the cpu and gpu to a ryzen 5 3600 and the msi geforce 1660ti gaming. x 6gb
Is it better to upgrade bios or get the r5 1600xR5 1600x
Should mention, the 1600x doesn't come with a cooler but the regular 1600 does.
If opt for 1600x,
CPU Cooler for Ryzen 5 1600X?
I am going to buy a Ryzen 5 1600X in the near future, and would like to know what cooler I should get to accomodate it. At the moment, I am strongly considering the Be Quiet Dark Rock 3, Cryorig H7, and Cryorig H5. I am also planning on overclocking my Ryzen CPU, although it won't get a very...forums.tomshardware.com
Should i just get a better motherboard??
Can i put a ryzen 5 3600 on the b450Would be a good idea. B450 & 2700x. 2700x comes with a cooler.
Is there a motherboard that i can just put the rryzen 5 3600 without doing anythingYes of course but if the motherboard isn't updated already (should say Ryzen 3000 ready) then need to get it updated.
Or go for an x570 for native support.
