Download and run HWINFO:
https://www.hwinfo.com/
Leave the 2 checkboxes unchecked and click Run.
Click on Save Report and Summary for Clipboard, then click Next.
Highlight everything that appears in the new window and copy-paste it here.
After that, you'll just need to provide the make and model of the power supply - if you don't know it, it's as simple as opening the case up, taking a pic of the label, and posting it through imgur.com.
talking about this?
Computer: MSI MS-7C02
CPU: AMD Ryzen 7 3800X (Matisse, MTS-B0)
3900 MHz (39.00x100.0) @ 3875 MHz (38.75x100.0)
Motherboard: MSI B450 TOMAHAWK MAX (MS-7C02)
BIOS: 3.30, 09/17/2019
Chipset: AMD B450 (Low-Power Promontory PROM26.A)
Memory: 32768 MBytes @ 1500 MHz, 16-18-18-38
- 16384 MB PC24000 DDR4 SDRAM - G Skill F4-3000C16-16GISB
Graphics: NVIDIA GeForce RTX 2070 SUPER (TU104-410) [ASUS]
NVIDIA GeForce RTX 2070 Super, 8192 MB GDDR6 SDRAM
Drive: KINGSTON SA400S371920G, 1875.4 GB, Serial ATA 6Gb/s @ 6Gb/s
Sound: NVIDIA TU104 - High Definition Audio Controller
Sound: AMD Starship/Matisse/Vermeer - HD Audio Controller
Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
OS: Microsoft Windows 10 Professional (x64) Build 18363.535 (1909/November 2019
