MATTBLASTER5000 Jul 1, 2020 37 1 35 Sep 16, 2020 #1 I think I accidentally set a setting and now it says chasis intrude. Please check your system. Fatal error. I can't get in to the BIOS to fix it. How do I fix this? Please help me.
Solution rocktalkrock Sep 16, 2020 Have you tried clearing the CMOS? Unplug the computer and remove the motherboards coin battery for at least 30 seconds to reset the BIOS.
rocktalkrock Judicious Jul 4, 2017 6,077 280 36,640 Sep 16, 2020 Solution #2 Have you tried clearing the CMOS? Unplug the computer and remove the motherboards coin battery for at least 30 seconds to reset the BIOS. Upvote 0 Downvote Solution
