can you run a gtx 1050 ti low profile on a 270 w power supply and is a gtx 1050 ti lp compatible with a dell optiplex 990 sff ?
thanks might upgrade my psuYes it will work with a 990 SFF. Yes it should work with a 270w PSU, though its not ideal.
really?Not going to be able to upgrade it since it is a proprietary form factor
