Question HELP!
May 1, 2021
Hey! so, my pc has some issue when i play games without v sync the game just stucks and i have to restart my pc by holding the power button but when i play with v sync the game crashes sometimes not everytime like in without v sync.
please help me out.
thank you
Lutfij
You should start off by listing the specs to your entire build. Often times a system that locks up or reboots is due to a PSU problem. Of not, then it's either an OS or a driver issue or both. List all the games you tax the system with and include the age of your PSU as well.
May 1, 2021
[/QUOT
Intel Xeon e5 1650 v2
1060 6gb
32gb ram
425w psu
It's a prebuild pc of dell.
Dell workstation t3610
punkncat
Ambassador
Go to Event Viewer and look at your Critical and Error tabs within. Open a search window and see what things mean. Some of it can be run of the mill, others are informative towards a problem.
I would expect some Event 41 which is a symptom of manual shutdown and/or PSU issue(s) much of the time. With it freezing in game I would expect to see other important details here as well.
The other go to check would be temps. Are you monitoring them?
May 1, 2021
Do i monitor temps using afterburner?
