help
steviemo03
60
can any one please help me ive iust put together a new pc turned it on formatted the hdrive and went into the bios set up changed the cpu speed exit and nothing!!! restarted and went to bios defaults and restarted went past the first beep and the asus logo, then the message `NTLDR MISSING` hit control alt delte and now i dont know what to do!!!!!!! mabey boot seq or something
asus a8vx-x
128mb gforce4 5200
80 gig baracuda
512 333 ddr
you might be experiencing some hdd data corruption due to overclocking your pci bus, this all depends on your chipset whether the pci bus can be locked or not, i recommend you clock down to stock speed and reformat your hdd and reinstall windows from scratch.
