Question Help
Sep 6, 2022
I don't know why but this past week my wifi has been disconnecting and recoonecting whenever im playing a game and I've did the eidt power plan thing and also the power management. Please help
Sep 6, 2022
Device name DESKTOP-8SCF2TP
Processor AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Installed RAM 16.0 GB
Device ID 18BD13C3-1941-4FA3-869A-31151564E421
Product ID 00325-81209-19506-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Netgear r6230
PsychoPsyops
589
66
19,090
Open 'Device Manager,' right-click the network adapter, click Properties, then the Advanced tab. Now, in the list of features, find the one that allows you to use 2.4Ghz, 5Ghz or both, and make sure "both" is NOT selected.
When "both" is selected, a lot of adapters will decide on which one is the best option to choose and may often switch between them, thus disconnecting the network connection in the process. Obviously, this shouldn't happen, but it can, unfortunately.
If you care about which option to choose, 2.4Ghz is the slower one that allows for longer distances, whereas 5Ghz is faster but has much less range.
5Ghz may not be supported by your router as it is newer, but it should match what ever your network is set to. 2.4Ghz if you're not sure.
