Help! =(
220racer
9
I have recently put together my computer, form what I know... everything went fine. But whenever i plug it in, it either simultaneously turns on and off (every component, fans and all), or it just has the light on the motherboard turn on, and thats it.
Another Update: I contacted Raidmax support, they told me to jam a paper clip inside the 24-pin power connector, I did so, and found out that the motherboard is the thing that really works.
