the best graphics you can get without running into bottlenecking issues is a radeon 7750. yes a dual core is enough for gaming usually but since your cpu is old you might want to upgrade it soon
id recommend a phenom 2 X4 940 cpu. but check your motherboard manufaturer website if this cpu is supported or not also you may need to update the BIOS.
but 7750 wont require a cpu upgrade so dont bother for now
What CPU would you recommend? My current CPU is a AMD Athlond 7850 Black Edition and would i need more power supply?
