HELPPPP!!!!!!!!! 4 OHM into 6 OHM car??
ne_Defiiant
Hello, i have just removed my 6 ohm car speakers and out in 4 ohm speakers.. is this bad?
Sorry, i am new to this stuff and dont really know what im talking about,, whats the difference between 6 ohm and 4 ohm?
Now if you don't crank on the volume knob you should be fine. Chances are, you do not have an aftermarket headunit. You can get a cheap 50$ Headunit at walmart that will handle 4 ohms no problem and maybe be an upgrade from the factory stereo headunit; spend a little more and you can get a better quality sound. This is what I recommend.
