Hercules Problem, Help!
patvdragon
22
So, I in typical fasion decided to rebuild my computer before game day, great choice... Here is my problem. I have a Hercules Fortissimo sound card (7.1), and I have had it running on my sytem with windows xp many for a year or so. I just bought a new mobo, the Asrock vtk88, and got everything working, save the sound card. When I load the drivers for the sound card, windows crashes hard. It then won't let me load windows again when I reboot unless I go in safe mode, and disable the hercules drivers. What can I do/ what is the problem? Any info would be appreciated, Thanks
Crashman
Polypheme
Former Staff
Try putting the card in a different slot.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Black_Cat
1,897
Uninstall the drivers. Reinstall the drivers but make sure you are not connected to the internet. If you have an ethernet connection physically unplug it before installing.
You've tried and failed. The lesson here is, never try again. -- Homer Simpson.
patvdragon
22
Nah, that isn't the problem, I know to do that, done it 4 times. This is a driver problem between my card, chipset and windows. Thanks though...
umheint0
947
You're sure you had your internet connection disabled? Hercules cards won't operate properly with the Microsoft-provided drivers.
umheint0's phat setup --> <A HREF="http://home.cc.umanitoba.ca/~umheint0/system.html" target="_new">http://home.cc.umanitoba.ca/~umheint0/system.html</A><--
