Question Hey cable help!
Vilionzo
53
Just bought RTX 2060, didnt plug it in yet, but after moving so many times between living places i lost the cables i didnt need first from my PSU, GPU requires 2x8 - 8 Pin connection, and PSU takes it PCIE 6+2 connection, could you help me find the correct cables in Lithuania?
According to the chart link I sent.....
If you look at the bottom where the TX-M series is....
It says it has one of those PCIe 8 pin cables "fixed".
Then below it says Type 4 PCIe with an orange dot under TX-M.
So I think it should work.
