Question Hey Guys My computer is not sending any power to the keyboard, mouse or monitor what is the problem?
Jun 14, 2022
4
The fans and lights inside are working.
This has happened before but turning it on and off a few times it eventually worked, but now it doesn't work at all.
Any help greatly appreciated.
4
sound like the pc is not working.
full system spec? include brand and model of the psu
PROCESSOR = AMD RYZEN™ 3 2200G - QUAD CORE - 3.50GHZ - RADEON™ RX VEGA 8 GRAPHICS
Memory = 8GB DDR4 2400MHZ ( 1 x 8GB) - ADATA PREMIER
Power Supply = TorQue 500 WATT ECO GREEN POWER SUPPLY 75+ CERTIFIED
Windows 10 Home™ Edition
Thanks for the reply is this enough info?
Also I forgot to mention that all the fans and lights inside are working.
Jun 16, 2022
6
Try listening/looking for a motherboard error code first - if there are leds or a buzzer on the motherboard you might hear beeps of see a code in the leds - the motherboard manual might tell you what it means.
After that, if you have a multimeter, unplug the leads from the motherboard and test the voltage on each pin. You'll have to short out the power_on pin on the main ATX connector to get the PSU to turn on.
