https://au.pcpartpicker.com/list/h2cXxG
Any improvements or more efficient components?
would like to drop it to around $3500 if you can
You already have a power supply or you forget to put one in? The 2070 will be hard pressed to reach 165fps at 1440p, unlikely to get over 100fps in most titles at ultra tbh, so unless you're playing fortnite on low, perhaps get a lower refresh rate monitor, a 144hz 1440p monitor will shave about $100-200 off, unless you really want the ips viewing pleasure, then forget what i said. I have a personal bias against water cooling, but I'll refrain. The only other place to save money is that case, there are so many cases on the market that perform well for under 200 that i don't see 350 for a 50lb chunk of glass and metal being worth it. But to each their own.
Yes, recycling a 750w PSU from a previous build!You already have a power supply or you forget to put one in? The 2070 will be hard pressed to reach 165fps at 1440p, unlikely to get over 100fps in most titles at ultra tbh, so unless you're playing fortnite on low, perhaps get a lower refresh rate monitor, a 144hz 1440p monitor will shave about $100-200 off, unless you really want the ips viewing pleasure, then forget what i said. I have a personal bias against water cooling, but I'll refrain. The only other place to save money is that case, there are so many cases on the market that perform well for under 200 that i don't see 350 for a 50lb chunk of glass and metal being worth it. But to each their own.
Thank you so much! I shall put your suggestions into consideration!!This should be better...
PCPartPicker Part List
Type|Item|Price
CPU | Intel - Core i9-9900K 3.6 GHz 8-Core Processor | $748.00 @ Shopping Express
CPU Cooler | CRYORIG - R1 Ultimate 76 CFM CPU Cooler | $99.00 @ PCCaseGear
Motherboard | Asus - ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard | $368.00 @ Shopping Express
Memory | G.Skill - Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory | $124.00 @ Shopping Express
Storage | ADATA - XPG SX8200 Pro 512 GB M.2-2280 Solid State Drive | $99.00 @ Umart
Storage | Western Digital - BLACK SERIES 2 TB 3.5" 7200RPM Internal Hard Drive | $179.00 @ Austin Computers
Video Card | NVIDIA - GeForce RTX 2080 8 GB Founders Edition Video Card | $969.00 @ Umart
Case | Thermaltake - Level 20 MT ATX Mid Tower Case | $114.00 @ Shopping Express
Case Fan | Cooler Master - MF120R ARGB 3in1 59 CFM 120 mm Fans | $59.00 @ PLE Computers
Monitor | LG - 32GK650F-B 32.0" 2560x1440 144 Hz Monitor | $479.00 @ Umart
| Prices include shipping, taxes, rebates, and discounts |
| Total | $3238.00
| Generated by PCPartPicker 2019-07-10 03:12 AEST+1000 |
Also, which PSU do you have??? Make sure its decent quality. With that kind of hardware, I wont risk anything below Tier A... https://linustechtips.com/main/topic/1045610-new-psu-tier-list/
That PSU doesn't look good. I would get something better. Modified list...Thank you so much! I shall put your suggestions into consideration!!
My current PSU is: https://www.pccasegear.com/products/23172/xigmatek-vector-g-750w-80-gold
