hey i need the best case and blu-ray drive for this build help!!
Your build is complete added the drive and case in.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($339.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($6.97 @ SuperBiiz)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($208.99 @ SuperBiiz)
Memory: Corsair Vengeance LP 16GB (2 x 8GB) DDR3-1866 Memory ($169.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($134.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($99.99 @ Amazon)
Video Card: MSI GeForce GTX 780 Ti 3GB TWIN FROZR Video Card ($669.99 @ Micro Center)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Newegg)
Power Supply: EVGA SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply ($169.99 @ NCIX US)
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer ($60.97 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $2081.82
The Phanteks Enthoo Pro just won case of the year for 2014 at Computex
http://www.newegg.com/Product/Product.aspx?Item=N82E16811854003&cm_re=Phanteks-_-11-854-003-_-Product
BR Burners are usually only $10 more so worth considering
Asus Player = $49
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135247
Asis BR Burner $59
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135252
The Seaonoic X-Series generally garners slightly better build quality ratings from jonnyguru and is cheaper. SuperNova gets 10.0 performance / 9.5 build quality ...X series 10.0 / 10.0
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151110
And BTW, 850 watts is more than enough for two 780 Tis .... the X-850 is $154
NViida specifies 850 watts
Guru3D specifies 800 watts
My power meter measures < 700 watts.
A $2k build deserves better than a $30 budget cooler. Grab the Phanteks for $65 and pick up an additional 7 - 10C of cooling.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011
The MSI 780 Ti has been $600 on newegg every other week for last 6 weeks.....start looking around Thursday
Finally, consider the MSI GD-65...it's a virtual feature for feature match up and down with the Hero, is better reviewed and is $40 cheaper. I love Asus but until the BIOS Clock Freeze thing is fixed, I put a hold on any more builds.
If ya do a web search of RoG forums, there's about a dozen threads on this issue. Asus announced a fix back in August but was only temporary, same with removing / replacing battery ... only temporary. The kast fix was announced in June 11 but teh promised BIOS update that is suppossed to fix it was not available as of yesterday.
http://rog.asus.com/forum/showthread.php?33895-Hero-Time-Clock-Problem/page3
If ya can wait, then by all means wait for the fix.... not that I don't trust them at their word but we have seen fixes announced before that just didn't "take". The fact that we still can't get the fix 2 weeks after announcement that it was available has me a little nervous.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($339.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive ($134.99 @ Best Buy)
Case: Cooler Master HAF X ATX Full Tower Case ($165.99 @ Best Buy)
Total: $2147.82
