hey my front headphone jack (3.5mm) stopped working on one side
kanva90
38
hey, i m using a CM 690III case and the front 3.5mm jack was working perfectly fine, it has suddenly stopped working on the right side only and when i connect the heaphones to the jacks at back the headphones work fine, well even plugging it into the mic jack in the front and reassigning it as heaphone in realtek hd audio manager makes it work fine in both left and right but when i plug the headphones into the green earphone jack at the front only the left works, please help me solve this problem
Thath is somehow a common issue in many cases. I got myself replaced mine twice for the same reason. It happens when you plug and unplug the jack conector too often, and it start "sliding" out of its place. The only way to avoid this I've seen is just not unplugging th ejack, and switching the audio device via software.
After 2 warranty replacements, I just sold my old case and got a high end one... still I now fear damaging it so I got switching via software as well, in the end. I was quite dumb there, gotta admitt : (
