Marijus332 :
What you think about this ? http://uk.pcpartpicker.com/p/fpbWyc
You still haven't told me what you plan to do with this computer... You may be spending money on stuff you don't need.
That said, its a sexy machine... if you can afford it, good for you. The only thing I think people might look twice at are
1) the PSU: on paper, its a good PSU, but some Corsair stuff is not as good of quality. I think the CX line is okay though...I'd check out its reviews to make sure.
2) why a single 8 gig stick of ram? You have a dual channel motherboard - better to rock two 4 gig sticks in dual channel. Otherwise, a single 8 gig stick will operate in single channel.
3) OCing that chip on air is definitely doable, but they tend to run on the hotter side. Just know that.
