Hey there im torn between two builds.HELP
most people would probably say go with the intel one, i would say get an amd 8350, the one you chose is quite an old one, it would still work out a fair bit cheaper and more than enough for that setup
their is a reason most people say to go with the i5 :)
there is but its down to personal preference, i go with amd because i dislike the way intel do business
Actually, I think a build based on a cheaper I3-6100 will perform better than either in most games and has a better upgrade capability.
The integrated graphics is quite good so one can defer on the gtx750ti discrete graphics card if budget is a problem.
the above reasons are why i am torn so i will go with i5 for all round (gaming + work?) or would the AMD perform better. The i3 i have heard would need updating later as many new games are core intensive.
a i5 will game MUCH better than a fx cpu and will do core heavy tasks a bit better than a 6300 and close to a 8350
lol thats not that relevant. you run the exact same software on either of the cpus so the only change is performance. with phones the majority of the experience is software based
