Question hey there!my problem is my pc just keeps on restarting on its own.........
Jan 17, 2020
my pc is hp pro 3500 series.....8gb ram.....gtx 660 2gb .........intel h61motherboard....a 350 watts power supply..........please tell me how to solve this
The problems are
  1. The 350W PSU can't handle the gtx660.
  2. You got the OEM HP, you may have the compatibility problem, like this from HP tech support.
https://support.hp.com/us-en/document/c03653200
3) The MB may not have the right BIOS.
You should try to use ( or borrow ) one less powerful GPU ( retail brand) to try, check the linker to see you can boot the PC with retail GPU. Also make sure your MB has newer version BIOS.
If you can boot the PC with other less powerful GPU (retail brand), buy a good brand 550W PSU at least. Otherwise, if you can't boot the PC with retail brand GPU, forget about the new PSU for your gtx 660. May consider to build PC by yourself.
Reactions: oldcracc
