HG10 N970 - Any Sli Ideas/help?
Al-Dazzlez
44
Hi all!
So basically as of late I came across the Hydro series HG10 N970,
This
And I thought; "What if this was used for SLi purposes?"
So I wanted opinions on the topic.
My PC is running a Palit GTX760, and a Galaxy GTX760, (the latter running the same BIOS as the Palit, both OC'd to +170mhz core, and +436mhz on the memory, stable so far)
The Cooling is fine, on load I average ~70 to 80 degrees Celsius on full load, so the reference blowers are doing fine, and I don't really mind the sound of a jet taking off. But for cooling wise, I wanted to know if running two of the Corsairs would fit, as I also have a Sound-blaster card running in between them for compatibility purposes.
The Board is an ASRock Z87 Killer Fatal1ty and the case is a CM storm trooper.
TL;DR
And I am only trying to figure out if 2 of these HG10's would fit with a small Corsair H series cooler on each.
ASRock Z87 Fatal1ty Killer
GTX760 Sli 2 way with a sound card in between.
CM Storm Trooper case
Thanks in advance.
Thanks for the help, I was just worried if the tubing would get in the way of the cards, or the cards being in slots that are so far away it affects their speeds 😛 Thanks again @i7baby
