Hi Asrock n68 vs3 fx Graphics Problem
ukgamers
27
Hi Everone
Im doing a cheap build from a friend the spec are below . Il set it all up but nothing is showing on the screen at all. I didnt think that this setup would need a graphics card or am i wrong ? if it dont need a graphics card then what eles could the problem be
19" HTC screen
Galaxy 3 gaming case
Asrock n68 vs3 fx motherboard
fx 4130 cpu
4 gb drr 3 ram
1tb hdd
Many Thanks
Gary
Thanks for posting that link for me . so it would need an external graphiics card
Another person on a forum said that the motherboard and cpu can not run together as the cpu runs at 125w and the motherboard is only 95w . So i would have to change the motherboard to one that runs at 125w
is that correct ? thanks
nar its for just surfing the net . Why would it be no good for gaming
Would the VTX Radeon HD 5450 Graphics Card - 1GB DDR3- PCI Express card be a better choice
Do you know of another cheap card that would be ok
thanks whats would be the best out of these for gaming and what ones wouldnt work
1GB HD5450 Sapphire Radeon Pci Express Graphics Card
XFX AMD Radeon HD 5450 1GB Graphics Card
EVGA GF GT 210 1GB DDR3 Graphics Card
Asus GeForce 210 Nvidia Graphics Card
MSI GeForce N210 Nvidia Graphics Card
Palit gt520 2GB graphics card PCI express
radeon hd 4870 x2 graphics card 2gb
VTX Radeon HD 5450 2GB DDR 3 PCI Express Graphics Card - 3.8GB Hyper Memory
VTX Radeon HD 6450 2GB DDR 3 PCI Express Graphics Card - VGA/DVI/HDMI
thanks
i think the 4870 x2 is probably the best out of those but you need a hefty power supply and it's very out dated. I would probably pick the hd6450 out of what you have listed ... it's a hair better than the hd 5450.
